Hey everyone im looking for a 07 ext 8.6 10 rear to do a axle swap , if its not crazy far i would travel or if you want to ship 908-966-3201 thanks chris,
1) Recommend adding your gear ratio to the request.
2) Recommend checking junkyards using car-parts.com, which is where most of us get ours. I found mine with a G80 about 100 miles away for only $400.
Do what Roadie suggested and run a search on car-part.com. I just checked for your area and found a SS rear end (stronger then the 8.6) with 4.10 gears for $650 and it is only 45 minutes away from you.
I searched 2007 / ChevyTrailblazer / axle assembly rear (w. housing) / all areas / distance / 08830
The next screen will give you a choice of engines and gear ratios, choose the 6.0 and search. The first one on the list is 45 miles away from you and is listed at $650. It will meet your needs and provide a strong axle to upgrade to.
