WTB: markmc 3inch body lift
c bausch
183
Hey guy im looking for a 3inch body lift new or used but in good shape pm me looking to buy asap
10,685
Regulator
2,496
It is available for pre-sale again. Check out this thread for more information.
envoyjoe
25
i all ready have the 2 inch where can i get just the 3inch blocks and bolts to make it a 3inch kit
Not the right thread for this, but Yes, sort of. I had the two inch before the 3 was available and switched to help make rear brackets. Your steering is fine, the blocks and bolts will be over 100 prolly close to 150 and you cant run your rear bumper cover unless you buy rear brackets, but not sure those are available seperately. The front is easy and just needs 1 inch longer spacer.
DJones
701
St. Petersburg, Florida
Zone OffRoad has them. $3.75 each. They are the ones markmc was using, and I'm assuming high-voltage uses them too. Zone Offroad link. I think you'll have to check your local hardware stores for the bolts.
Most local hardware stores won't carry the size and grade of bolts needed...FYI
06_4.2_4x4_ls
