Guys,
My Silverado WT17 regular cab
Started to loose the needle reading.
Just a couple of hours ago I started it and the normal needle procedure on all the cluster works.
Goes all the way up and the set in the reading for rpm,temp , volts and all.
But the tank needle stayed like I was out of gas
But I don't see the warning on the LCD panel ,
No beeping , nothing .
Then after 2 mins driving it goes back to normal , then 5 mins after dead again.
It does it intermittent, no pattern.
I found this thread
gmtnation.com
In the 17 where are the cables going from the tank to the cluster in the dashboard.
Or goes to the PCM 1st?
I found this thread
Fuel guage
Hey all, '99 K1500 Suburban gas guage. First the history. Guy I bought the truck from said he had a fuel pump put in. The gas guage worked prior. Didn't work after it left the shop. He never confronted them. I changed the cluster out of curiosity. No difference. I think the shop effed up...
