Wierd Application of ABS when turning and braking
CaptainXL
I have noticed a weird phenomenon with my '05 XL. Basically what happens is that when I am maneuvering in a parking lot at slow speed and I turn the wheel while braking I notice the ABS kick in for a second or so. Very strange. The only thing I can think of is that the ABS sensor wire is loosing connection.
Mine did that for a while. It was because I had a bad hub bearing that was allowing enough play for the sensor to loose track of the wheel speed on occasion, making it think the wheel locked up and triggering the ABS.
If your bearing is fine then it is possibly just a mucked up sensor. Check the plug for any grime, maybe remove the sensor and clean it.
CaptainXL
I just jacked up the front of the truck and spun both tires and they won't spin at all...very stiff. I guess this means the bearings are going? I didn't notice any play when grabbing the top and bottom of the tire.
SBUBandit
597
My old grand am used to do the same thing and it was the wheel speed sensor. As for the wheels being stiff to spin, I just had to replace the bearings on the TB, and I knew they were going from the sound. The truck sounded like it had mud tires on it anytime i went over 35. Not a bad job overall though.
jrSS
Well at least u know u have good ball joints. Lol
RayVoy
939
CaptainXL said:
I just jacked up the front of the truck and spun both tires and they won't spin at all...very stiff. .
It may also mean, that you have a brake problem, the pads may not be releasing.
My first guess would be dragging brakes as well, but both wheels? Hmmm......is the front diff engaged?
CaptainXL
Nope. I also removed the drivers side caliper and its hard to turn unless I rotate it with both hands. Feels like trying to rotate a much larger mass
