On a 2014 Silverado with the optional KNP transmission cooler option ... does the fluid go into the cooler in front of the radiator first, and then back through the radiator? Or the other way around. Does it matter?
Normally, auxiliary coolers are plumbed to flow through the radiator cooler first and then into the aux cooler to then go back to the tranny, as per the image posted above.
I am going to add a trans cooler to '07 Tahoe 5.3. Which line is leaving the radiator cooler headed back to the trans? This the line I want to replubm to goto aux cooler to chill the 190ish degree fluid before headed back. Also, do you any problem with using tubing cutter to cut metal lines and slip hoses on with clamps? or is pressure to high to trust this? Use to do this back in the day with 350 and 400 THM's. Thanks the for input.
On full size trucks, the fluid flows out of the top cooler fitting on the rad.
I've used tubing cutters lots of times. Makes a perfect cut for this. My only advice is to double clamp each hose to avoid an impromptu fluid flush on the side of the road in -30c (ask me how I know).
I ran into this same issue on my 93 K1500. Without any research, I assumed the input was the top line. Well it was not. As I sat and watched the clear tube I attached to it, waiting for the fluid to come out. Any moment now. Any moment now. Well the fluid came out all right, all over the engine bay and ground. Not to worry though, this particular engine must have come from the GM factory without gaskets so it was no worse off.
