Which way does relay #42 (front washer pump) go in the fuse box..??
davenay67
I am tracing down a non-working windshield washer problem, and went to swap realy #42 with #38 as I know the rear works for sure. However, my fingers fumbled the relay just as it came out and now I don't know which orientation to put it back in....I have a 50% of getting it right but would prefer to be sure. :)
Could someone either snap a picture of the top of their fuses, or perhaps confirm the which pin settings I should be aligning.
Thansk..!!
Dave. :)
By design they will work either way. Here's a pic of mine.
:iagree: The solenoid is controlled by a wire on two opposite corners and the switch uses the other two corners, esentially making it bidirectional. Some of the other relays do not have the same configuration and only have one way to put them in.
Awesome....thanks very much guys....:thumbsup::thumbsup:
One of the extremely rare times where the electrical designers had a clear opportunity to choose a way to do it right, and a way to do it wrong and screw the owners - and they CHOSE WISELY!!!! :wootwoot: :thumbsup: :rotfl:
Wish they did the same on all the other cock-ups they committed. :hissyfit:
A E
