No 100% sure but on Amazon there are reviews that state you should get the original (from factory) gasket. I believe it's the steel one. It is better. Did you get an ACDelco water pump?
No I caved since there are good reviews on this one. Has the stamped steel impeller and I needed it that day. However I put off the swap so it's a moot point now. I figure there's a reason GM went with a steel gasket.
