Wheel spacers?
Dicbutkuss
9
Kansas
I would like to get some info on where to find some smaller wheels spacers for my Trailblazer I am running stock wheels but would like to go up to 245/75r17 instead of /45/70r17 I just need to clear the ball joint but sill have enough room to fit a wrench if needed
14,950
You should not have an issue without having spacers.
Dicbutkuss
9
Kansas
Sorry forgot to add if the tires have any sort of nob to them they don’t clear in the picture you can see with 70 it is very close
Dicbutkuss
9
Kansas
In added a picture to my last post as you can see it is very close the way it is that’s why I am trying to find wheel spacers
Boricua SS
3,080
I had a set of BORA 1" wheel spacers on my SS and had zero issues. Not sure if you guys have a vendor here that makes wheel spacers for you (liftmiester, etc...), but BORA is pretty well known in the spacer field.
Did you shave your studs down for the 1 inch spacers? I had to for my 1.3 inch. It's why 1.5 is typically recommended since it ensures you do not have to shave the studs.
Boricua SS
3,080
nope, they bolted right up. Let me see if i have some old pix. Once i got the 22's, i sold the spacers.
If your wheels have the right relief holes it works to have studs through. My vette wheels worked with thin spacers, but the stock TA wheels would not n would require stud grinding on my car.
chirobo1
