wheel bearing on a silverado
scirilo
5
Just replaced a passenger side wheel bearing and put everything back together, and the tire won't spin. Any ideas?
Feb 24, 2012
133
what did you torque the axle nut to?
jimmyjam
you're supposed to torque to something light (12 ft lbs maybe) to seat the bearings then back off and hand-snug down, if the cotter pin doesn't line up, loosen to get it to fit.
McGMT
621
scirilo said:
I just tightened the axle nut as tight as I could with an impact wrench.
That might last 15k miles or so, 20k if your lucky.... :nono: You just ran the inner and outter races together and now it is going to wear like mad...
Its usually somewhere around 100lb ft or so, 103 on a TB so its about the same on a Silver...
scirilo
5
So what should I do?
McGMT
621
Return that one and get another one. If your lucky the parts guy wont realize you destroyed it...
McGMT
621
scirilo said:
return the wheel bearing?
Yea, return it defective and hope that the guy behind the counter doesn't realize that you destroyed it or your gonna have to buy another one...
scirilo
5
ok just found out that there is a heavy half ton, which this truck isn't the heavy, and so that bearing is the wrong one. Thanks for your help and input.
McGMT
621
No problem, next time don't crush it with the impact....
jimmyjam
woah... are we talking about sealed bolt on hubs like the trailblazer
or the spindle style
if its a sealed unit, then just torque the shit out of it
but if it is the spindle style, then you only torque to 12ftlbs, loosen it and then hand tighten. DO NOT torque to 100ftlbs
McGMT
621
Don't ever ever "torque the shit" out of a sealed unit... ever... You pinch the inner and outer races together against the bearing and ruin them, that's why some people wonder why every single one they put on is garbage after 20k miles... And yes, its true if it is a spindle not to torque it down... Just ffs don't tell someone to torque the shit outta a sealed unit because that is false information and a worst case scenario.
My driver side bearing quit 30k miles after being torqued way down to something like 250+ ft lbs, although it was the original bearing and died at 150k... I broke my breaker bar trying to get that axle nut loose :crazy:
New one is torqued at 100 ft lbs
jimmyjam
fair enough. never torque the shit out of anything
however i don't see how it would damage the bearing. you're just clamping both sides of the inner race. you're not pushing the bearings together unless you're crushing the race itself. that would be impressive
McGMT
621
First, who cares, anyone who is a real mechanic knows theres a reason they come up with torque specs, its not just cuz someone gets bored and starts making up numbers.
Second, not every bearing you buy is going to have a one piece inner race, some are a split race with two ends.
Either way, there are torque specs for just about everything on a vehicle and they are there for a reason, people come here for help and information to get and keep these vehicles on the road the cheapest way and the most reliable, The head is one piece your clamping onto the block, no way your going to crush the head, are you going to torque the shit outta that?
I'll admit I primarily use the German torque spec gootentite for most things. I didn't have a torque wrench for years. I have done brakes, suspension, and entire rear axle swaps without any torque wrench :lipsrsealed: I think for some things like brake caliper brackets the torque spec is like the minimum torque to keep it on there. Other things, yeah, you don't dare go over the spec as you'll smash things, or warp stuff.
MEHMET ONUR
