NEED HELP What's the part called?
Boatman
50
Hey guys,
I had to replace my sunroof awhile back and still can't find 1 part to make everything complete. It's a little bump stop on the wind deflector, and I only have the one for the passenger side. I'm looking for one for the driver side because without it the deflector goes nuts in the wind and makes a lot of noise. Any suggestions? I've attached picture of the one on the passenger side.
I have the same problem on my TB but the passenger side. Don't know the name of this thing and don't know if you can get them from the dealer neither. And getting them at a pick-a-part would be impossible unless you can sneak in a power pack to power up the truck and open the sunroof (that's if the key is in the ignition too unless you want to pull the ignition switch too to activate it). So much trouble for such a tiny part!
Boatman
50
It sounds like we are both in the same boat. It's so annoying. I need to find a wrecked TB where the sunroof glass cracked or something. With all that said...... Want to ship me the one you have?
Uh, no.
Boatman
50
Damn, well I tried. I almost wish someone with a 3D printer could make one. It would be easier than trying to get one from a junk yard.
Or remove the deflector.
Boatman
50
Did you do this? Without getting into to much detail this is the reason I replaced my entire sunroof.
No, not yet but you can see what it sounds like by just holding it down with your hand. Turns into a low level drone kind of noise.
budwich
2,049
kanata
be a little creative yourself. try some hard wood "blank" first and "copy" your other side's "part". If you are successful, you can try machine another material (plastic or metal).
coolasice
1,019
Northern Maine
I looked over parts diagrams and only thing I can see is that it is part of the deflector(12476161 DEFLECTOR,SUN RF AIR(W/STOP BUMPERS) $67.82).
what if you made a small limit strap instead of the bump stops?
That is a great idea!
SnowBlazer
5,775
Colorado Springs
I don't have a sun roof but would it be possible to use washers?
budwich
2,049
kanata
get a rubber foot, ones that they used on electrical equipment or equivalent and silicon it in place after you "shave" it to "fit".
better still, go to Lowes / homedepot and get a rubber grommet and "work" it accordingly.
Boatman
50
I think I'll be able to finagle something using some wire, epoxy, and a piece of rubber this weekend. We'll see how this goes.
MEHMET ONUR
