Hello good people out there......
I have a problem I'm hoping you can help me with. I was about to start the work of replacing the front and rear Stabilizer Bar End Links and bushings on the family TB tonight and I noticed the Right Upper Control Arm bolt a bit out of place. This is not normal right(see attached pic)? I tried to hand tighten it this morning but couldn't move at all but didn't want to put too much into the pul as i could have stripped it even more. What torque are these bolts set at so it may help me to estimate the power i should put into it?
I'm wondering if the last allignment I had with FireStone may have stripped the bolt while completing the allignment. The did explain to me that my allignment was better in some but worse in others. Either way.... do you think this could be causing a steering vibration and an occational thump, metal sounding creak while driving?
See attached.... and thanks for all the help you guys provide.
