Brake pedal does nothing
R Redbeard Member Jan 26, 2013 3,479 Aug 1, 2017 #481 Brake pedal does nothing Reactions: Tiggerr, Matt, Mooseman and 1 other person
$ Khalid ! 9130 Member Mar 30, 2016 1,465 KSA Aug 1, 2017 #482 Brake pedal does nothing So is it supposed to do something?? Reactions: Mooseman and Redbeard
northcreek Member Jan 15, 2012 3,319 WNY Aug 6, 2017 #483 How do you change motor mounts ? Kinda like this.... Reactions: Redbeard and Mooseman
Mooseman Moderator Dec 4, 2011 25,331 Ottawa, ON Aug 6, 2017 #484 Only one HVAC speed does not work Well, don't use it! Reactions: northcreek, Redbeard and $ Khalid ! 9130
R Redbeard Member Jan 26, 2013 3,479 Aug 7, 2017 #485 No power to one front power outlet. use the other one then. Reactions: northcreek and $ Khalid ! 9130
R Redbeard Member Jan 26, 2013 3,479 Aug 7, 2017 #486 Coolant still bubbling boiling the hell out of it now?
R Redbeard Member Jan 26, 2013 3,479 Aug 7, 2017 #487 bad smell from hvac but does it leave a bad taste in your mouth?
northcreek Member Jan 15, 2012 3,319 WNY Aug 7, 2017 #488 bad smell from hvac... FYI, HVAC is not an acronym for (Her Vagina & Ass Crack). Reactions: Redbeard
R Redbeard Member Jan 26, 2013 3,479 Aug 8, 2017 #489 Water Leak Rear Hatch duct tape fixes anything. Reactions: Tiggerr
northcreek Member Jan 15, 2012 3,319 WNY Aug 8, 2017 #490 2004 Envoy Keyless Entry Issue... Like this ? Reactions: $ Khalid ! 9130, Tiggerr and Redbeard
northcreek Member Jan 15, 2012 3,319 WNY Aug 9, 2017 #491 Clogged Cat Question.... What's to ask? Reactions: Tiggerr, Blckshdw and Redbeard
R Redbeard Member Jan 26, 2013 3,479 Aug 10, 2017 #492 Clogged Cat Question That's an exhausting problem Reactions: northcreek and Tiggerr
R Redbeard Member Jan 26, 2013 3,479 Aug 15, 2017 #493 Question about having PCM Tuned is that for AM or FM reception? Reactions: Mooseman
R Redbeard Member Jan 26, 2013 3,479 Aug 18, 2017 #494 Ac Compressor clutch not engaging You mean it's old enough to get married? Already? Reactions: $ Khalid ! 9130 and Mooseman
R Redbeard Member Jan 26, 2013 3,479 Aug 22, 2017 #495 Remote start question sometimes you just gotta be there Reactions: northcreek
R Redbeard Member Jan 26, 2013 3,479 Aug 23, 2017 #496 The Quitting Smoking Thread So you ran out of leaf to smoke and are now resorting to "thread" to smoke? Holy Smokes. Reactions: northcreek and Mooseman
R Redbeard Member Jan 26, 2013 3,479 Aug 25, 2017 #497 Fuel pump thoughts, well do I want pressure or volume today? You can have one or the other, but not both at the same time. Reactions: Mooseman
northcreek Member Jan 15, 2012 3,319 WNY Aug 25, 2017 #498 Looking for member ? I think I see him... Reactions: $ Khalid ! 9130, xavierny25, Redbeard and 1 other person
northcreek Member Jan 15, 2012 3,319 WNY Aug 27, 2017 #499 Front differential toast... Doesn't sound very appetizing........I'm sticking with butter. Reactions: Tiggerr, Mooseman, Redbeard and 1 other person
$ Khalid ! 9130 Member Mar 30, 2016 1,465 KSA Aug 27, 2017 #500 Front differential toast.. Can I get an omelette with that..... Reactions: Redbeard, Tiggerr and Mooseman
Mooseman Moderator Dec 4, 2011 25,331 Ottawa, ON Aug 30, 2017 #501 Sunroof crunch New cereal from Kellog's! Reactions: Tiggerr, $ Khalid ! 9130, northcreek and 2 others
R Redbeard Member Jan 26, 2013 3,479 Sep 2, 2017 #502 Thoughts on lighting up cup holders mine don't smoke. Reactions: Tiggerr
R Redbeard Member Jan 26, 2013 3,479 Sep 2, 2017 #503 Replacing climate control light bulbs So is climate change man made or not? Reactions: $ Khalid ! 9130 and Mooseman
R Redbeard Member Jan 26, 2013 3,479 Sep 4, 2017 #504 Elctrical mysteries Or how to play "hide and seek" in the dark, yet idiot lights continue functioning. Reactions: Mooseman
Mooseman Moderator Dec 4, 2011 25,331 Ottawa, ON Sep 4, 2017 #505 Strange AC behaviour Maybe it's DC. Reactions: Redbeard
Mooseman Moderator Dec 4, 2011 25,331 Ottawa, ON Sep 10, 2017 #506 Chasing vehicle Not Starting How can you chase a vehicle that's not starting??? Reactions: fletch09, Redbeard, Blckshdw and 2 others
northcreek Member Jan 15, 2012 3,319 WNY Sep 11, 2017 #507 TPS Chirping Sound There's the problem.... Reactions: Redbeard, xavierny25, Tiggerr and 2 others
R Redbeard Member Jan 26, 2013 3,479 Sep 14, 2017 #508 Accessory Noise isn't most noise unnecessary? Reactions: Mooseman
R Redbeard Member Jan 26, 2013 3,479 Sep 14, 2017 #509 Intermittent Codes - 50 of them? with this many and you still can't catch one?
R Redbeard Member Jan 26, 2013 3,479 Sep 16, 2017 #510 Pulling the transmission this weekend where to? Reactions: northcreek
northcreek Member Jan 15, 2012 3,319 WNY Sep 17, 2017 #511 Pulling the transmission this weekend.... This'el get that sucker out... Reactions: Tiggerr, Mooseman, Blckshdw and 1 other person
R Redbeard Member Jan 26, 2013 3,479 Sep 21, 2017 #512 Critters living in your vehicle Are the low lifes from your side of the family or your spouse's? Reactions: Mooseman
R Redbeard Member Jan 26, 2013 3,479 Sep 22, 2017 #513 Chasing vehicle Not Starting How do you run a race without even starting? Reactions: Mooseman
northcreek Member Jan 15, 2012 3,319 WNY Sep 23, 2017 #514 Tire wear question... Reactions: Redbeard, Tiggerr, Mooseman and 2 others
Blckshdw Moderator Nov 20, 2011 10,681 Tampa Bay Area, FL Sep 27, 2017 #515 Electrical gremlins While they're looking for something to break in your vehicle... ... and after they find what they're looking for... Reactions: Tiggerr, northcreek, Redbeard and 1 other person
northcreek Member Jan 15, 2012 3,319 WNY Sep 28, 2017 #516 Electrical gremlins... I think they're gasical not electrical Reactions: Blckshdw, Matt, Redbeard and 2 others
R Redbeard Member Jan 26, 2013 3,479 Oct 2, 2017 #517 What do I need for Mark's lift and Mike's bumper? a wheel barrow full of cash comes to mind, and if you have to ask you probably can't afford it either. Reactions: Matt, Tiggerr, Mooseman and 3 others
northcreek Member Jan 15, 2012 3,319 WNY Oct 2, 2017 #518 Different tires on 4WD.... is this different enough? Reactions: Tiggerr, Redbeard and Mooseman
northcreek Member Jan 15, 2012 3,319 WNY Oct 10, 2017 #519 Slow rev in park... yes! you should always do this, even in reverse... Reactions: Redbeard
Mooseman Moderator Dec 4, 2011 25,331 Ottawa, ON Oct 10, 2017 #520 Slow rev in park. Sounds like a title to a song or movie. Reactions: Redbeard
