What came in your mail today?
A couple high beam splitters so I can start running my bi-xenons with some cree high beams.
Also got a 9006 extension cuz from where my relay is to where I have to plug in it awfully tight.
Also, Dmanns67 posted the TRS 4th of July discount, but if you get anything after this weekend use the code TRSHJ for 10% off. Dave gave me that code as well.
Btw...HJ doesn't mean what you guys think it means. :lipsrsealed: :rotfl:
LEDs and ACDelco headlight relay since mine is acting up again.
Amber LEDs are likely going in the TB.
So the one on the left was allegedly the correct rebuild kit for an 84 corvette. Well, it was not. So I ordered the correct one (17si) and that the one on the right, which came today and is in the vette. Still do not know if it charges or not yet though. :raspberry:
Reactions: jpimp and Mounce
Got a thing from the insurance co about how did they do with my claim. Not good timing for them since I been waiting 2 weeks for a response from the adjuster...
Reactions: Eric04
Spare set of Morimoto 3Five H1 4300k HIDs. Hard to pass up for $15. Received my missing hardware for the MMH1 kit I bought for the F150.
Also, a badass bottle opener I bought for the wife's bday. Made from a .50 cal bullet. Bought it from bottlebreacher.com The owners were on the show Shark Tank. Basically small business owners pitching their idea in hopes of getting an investor for startup or expansion of their business/product.
Mishimoto compact baffled oil catch can. I was going to add some steel wool to a cheap can but I caved and will give this one a try.
I told myself I wasn't paying $100 or more for a catch can but after researching them, it's not a terrible price and after examining it...the can is very well build and actually quite heavy, I wish the hose barbs were metal and not nylon but there's no real pressures to deal with...I planned on changing them anyway.
There is also a flush drain plug and I may add another type of plug and attach a tube to the drain, but for now I'll see how much it traps.
I'll get it mounted and post a pic.
Got some cheap silver valve caps to replace the black plastic on the DD
Books and some new e-juice...the usual caramel cappuccino and a new one that tastes like almond joy (me likey!).
New rear hubs for the wife's Rav4. Went with the abs hubs (even though it's drum non-abs on the rear) because they were about 1/3 the price a pair than non-abs hubs from Detroit Axle.
Putting those on probably Friday night.
Received the rest of my solder kit. Solder tip cleaning wire, small tip for the iron, and a LED flasher relay for the F150. Apparently, wiring in resistors does not work. Did a little research on a forum and everyone upgrading to LEDs in the turn signals went with this $12 relay. Hopefully it works.
Sib said:
Got my exhaust tip in today. Plan on chopping the trash can this weekend. Looked big so went outside to check if it was too wide and fits poyfectly.
I'm sure it's some where in here but what size and length pipe is used when doing the trash can delete? I'm not looking to wield it on just strap or clamp on.
It's not in this thread, Google "resonator delete gmtnation.com" and sift through the threads, you'll find it.
Reactions: xavierny25 and Sib
Haynes manual for the Rav came last night. My only issue is it's for 1996-2012...there's a lot of info to sift through for the 02, but, it doesn't look like it's too big of a deal for the rear hubs, even though it's got drums on the rear.
Yesterday i got three seperate bills for the dentist...seems they could charge less if they were smart enough to put them in one envelope and save the freaking postage...
They could take some lessons from the Tooth Fairy who leaves money with free home delivery :biggrin:
Scored a deal on factory original spark plugs for my picky ass 2001 Volvo s40. Picky because she run like shit with any other plugs in there.
Got my lil led license plate bar
My replacement thermostat arrived. This one will handle dual fuel properly. Ordered the wrong one when I got the new furnace/heat pump so it won't run the aux heat properly :duh:
My replacement pressure washer pump from my pawn store pressure washer find. Engine is good, pump is in need of alot of service so I just went and ordered a new one .Replaced it with an AR 4000 PSI 4GPM pump...with external unloader.... :woot: .
Now I can clean some stuff
Just this. :biggrin:
Water pump for buddy's race truck.
Owners manual for an old router.
Reactions: hrddrv
Got part of my order from ebay. Transgo kit and corvette servo are lost. They most of dropped that off who knows where. So I'm going to be going back and forth with ebay seller and ups this morning. Smhuploadfromtaptalk1439375329267.jpg
scottjohnson247
