What brand of thermostat?
BrianF
Well-Known Member
Still have to put a new on in on the 4.2. I see various brands, gates, Stant, Mahle and Gm. Any preferences? I am not sure who GM sources theirs from though.
thanks
Capote
Platinum Supporter
thanks
AC Delco
Mektek
Well-Known Member
I used a motorad - made in Israel with a German heat motor. Still OK a year after install. It has a slightly different design than the OEM.
It would be good if someone just sold a replacement heat motor, instead of the whole outlet assembly.
ACDelco. Tried a Gates, it worked but found the temp a tad low. ACDelco in and temp was where it should be.
Capote
Platinum Supporter
Gates seems to be a hit or miss.
xavierny25
Well-Known Member
I replaced my oem with a stant and it crapped out 1yr 1/2 later. I went AC Delco last time around and it's been good as new.
paul2005tb
Silver Supporter
I used AC Delco on my replacement. I still cant understand what GM gains by selling it as an entire assembly rather than selling just the thermostat that sits in the cradle. The aftermarket providers should just sell the thermostat separately is capture the market. I know, too small of a market !
Forum statistics
Messages
569,724
Btm88tc
Top Bottom
