- Apr 9, 2012
- 922
Hi all!
I'm trying to track down a gremlin in the Envoy. Past few months since summer decided to show itself I've been experiencing intermittent voltage drops, usually drops to the 11.5-12 range give or take. Usually only happens for a second or too regardless if I'm at idle or driving. This only happens when I'm running the A/C, and when the voltage does drop the air seems to slow down from the vents and then picks back up again once the voltage hits the 13.5-14 range. I checked the connections running to the battery and back of the alternator but couldn't find anything. I don't recall having this issue last summer or with my previous TB. Is this usually a sign it may be the alternator? or something else entirely? Was also wondering if it may effect the A/C performance, it blows cool but not cold enough to my liking which I assume is an entirely different issue.
Only work I've done so far was replace the blower module, since I lost all fan speeds in June and the module decided to melt itself to the wiring harness. The voltage issue I'm experiencing has been ongoing since about May.
