Hello all,
Posting this one for my dad's 2002 Trailblazer EXT with about 175,000 miles on it.
He seems to be having a problem with his fan clutch but I can't be sure why or how or if it really is the fan clutch or not.
He is on his 3rd fan clutch, the first being OEM which died and was on the full stuck on position, then he bought a cheap chinese made fan clutch (big mistake I know) which helped the problem but there was still something wrong for it's entire life. It came with the infamous ticking sound which I believed was the fan clutch trying to engage/disengage but failing to do so. The biggest problems were that it took very long to go away at first start, like sometimes it needed a full minute of driving, even in winter on cold days. As he put more miles on the car, we started getting SES lights which threw codes for a bad fan clutch. We took an 8 hour drive to North Carolina last summer and over there it seems like it died totally. When we slowed down on the highway due to traffic, the fan would get stuck on the full on position and it wouldn't stop, especially with the AC on and even more with the AC running in the back (EXT version so it has the roof vents). With the AC running it would not turn off at all. The gauge read 210 temperature.
When we got back home, he replaced it with a Dorman or Hayden fan clutch which seemed to be fine for a little bit, and better quality then the old one, but it still had the issue of taking a very long time to turn off at first start. I know this isn't normal because my 2002 Envoy never does this, it turns off in seconds at most.
Now after months of driving, the fan clutch turns on and off rapidly and cycles over and over again when cruising at highway speeds. It sounds annoying, like someone is turning a vacuum on and off and repeat. This happens without AC on but with the AC on it happens more frequently or gets stuck on the full on position.
Next, my dad also has a transmission problem. When cruising highway, especially going up on a hill, the transmission is almost as if stuck in 3rd gear. It never kicks into 4th or overdrive unless he lets go of the throttle completely, but even when he pushes it again just a little bit, it jumps right back to 3rd with high RPM every single time. He claims this started happening when the fan clutch started failing or screwing around. Coincidence?
For me, it seems hard to believe that both fan clutches died in such a short amount of time and both have the same problems from the start. Is it possible that the PCM could be screwing my dad over and also messing with how the transmission works? I know the PCM controls the fan clutch and it can be tuned to change how the transmission works. I also read that flashing the PCM is not necessary and will only improve AC idle performance. But maybe in his case it will do something more? Or is this what he gets for getting a non OEM fan clutch? Will a better quality or OEM GM fan clutch help? Does the transmission have any correlation with this?
Any thoughts would be appreciated.
Thanks for reading.
Thanks for reading.
