Weird exhaust flow felt at tailpipe
blackout51
157
I left me truck heat up to normal and was curious so I set my hand under the tailpipe and it felt normal then a small puff and then normal and another puff, it just kept going like this continually, is this sign of a misfire or is this normal? I just got a new catalytic converter put on and don't want to ruin it with a misfire. Also note that the check engine light is not on.
CaptainXL
Yeah probably nothing. Some misfires at idle are normal. I would get the compression tested if it has never been. It's just a preventative maintenance thing.
I would also make sure that whatever caused your catalytic converter to fail has been corrected.
blackout51
157
Well when I got it the thermostat was bad and it had been running too cold for who knows how long, plus my plugs went bad about a month after that and it misfired really bad in all cylinders for about half a mile so I could get home, once those were fixed everything cleared up fine and it runs normal again, it just concerned me a little knowing I just put a brand new cat on there.
andrew94LT
