- Oct 18, 2012
- 157
So just recently I've noticed between 60-80 the steering wheel shakes more then normal and the alignment is off a little bit. All the wheels still look balanced but you never know, I'm just curious what else could cause this
RayVoy said:It is impossible to tell if a wheel is balanced by looking at it.
Have the balance checked, have the alignment checked (you may need new tires) and that will probably fix your problem.
If they used the silver duct tape instead of the proper black to fasten the balance hamsters to the inside of the tread, one of them may have come loose. That would match your symptoms. Insist they use the proper tape next time.blackout51 said:...do you think it is something messed up on the inside of the tire?
the roadie said:If they used the silver duct tape instead of the proper black to fasten the balance hamsters to the inside of the tread, one of them may have come loose. That would match your symptoms. Insist they use the proper tape next time.![]()
blackout51 said:So just recently I've noticed between 60-80 the steering wheel shakes more then normal and the alignment is off a little bit. All the wheels still look balanced but you never know, I'm just curious what else could cause this
northcreek said:By alignment I'm assuming that you mean the steering wheel is not centered.If that's the case you might want to check things like ball joints and tie rod ends for slop.I had a similar problem on my last Tahoe and found that a lower control arm bushing had disintegrated..Mike.
