So this just happened.
I just added new fluid in my power steering and ready to drive around to mix it in. Put the key in, turn to on, and turn to crank. Vehicle cranked for a sec, then I heard clicking, then the whole car went dark. I turn the key back and realize it's been locked in ignition. I turned it on and off tried to free it until the ignition switch locked my key to off position.
OK, maybe the battery finally quit, but I still have my jump starter. I pulled it out and connect to positive side and negative side of the battery. Jumper starter showed 'ready' with 14.4v. However, the car is still in dark and ignition switch remain locked even with external power. That's strange, I jumped out and fiddle with the positive cable. The car suddenly gave out a loud honk, I now have interior light with a battery light on dash. Hook up the jump starter and try again, but ignition switch still locked and don't let me pull key out.
What the hell just happened? Am I blowed a fuse, or our GMT360 will not recognize jump starter and require a disconnect to reset?
Any help is needed!
Any help is needed!
