- Aug 25, 2012
- 955
I figured this would be best in off topic as it is more of a question about a "tool" I purchased recently. I just bought myself a Mighty Vac MV7201 plus vacuum & dispenser pump. I bought it mainly for use on my jet ski so I can easily drain the oil out through the dipstick tube as well as clean the vacuum pump out and then pump RV antifreeze into the engine and intercooler for the winter months. My question is that since this is such a versatile tool in that you can use it both to siphon as well as pump fluids and air, what would be the tools recommended for fluids on my envoy and other vehicles? They sell accessories that allow you to help get rid of air pockets in the power steering system by using a cone shaped plug that you insert into the top of the power steering reservoir as well as another accessory that allows you to draw brake fluid from the bleeder valves so you can do a brake flush job on your own without the need for someone to depress the brake.
Do you guys think that the tool for evacuating air from the power steering system will work on our platform? I know some others on the market recommend drawing the air with a tool that fits into the power steering reservoir. I will be getting the brake bleeder adapter to make things easier when I do brake jobs. Any insight on this would be totally appreciated!
