Unlocking factory bose radio
TexazReece
Hello I just swapped out my factory bose headunit to another factory bose headunit with 6 disc changer. I installed it it first said locked then not locked and now its locked again. My question is can I unlock it myself rather than paying stealership $75? I thought there was a thread for unlocking radio but didn't come up in search. Thanx in advance for your help
Boricua SS
3,080
i think you might have to bite the bullet and go to the dealer... in all my readings about factory swaps throughout the multiple forums, i have never come across them being unlocked without a dealership... but then again, we could be wrong.. hopefully others chime in with their experiences...
Mark20
1,630
I've seen services on the web but don't remember the prices.
4,023
The radio has to be programmed with your VIN...pretty much tech2 only. Looks a trip to the stealers for you.
mwking
9
I made the swap from a single disk factory headunit to a six disk bose unit as well. The other posters are correct, you need someone with a tech2 to program your vin into the headunit. Before you do though, if you haven't already, pull the fuse from the radio for a second and then turn the key to acc. The radio should be unlocked and you should run though all the functions on the radio to make sure it is working properly before you spend the money to get it reprogramed. As soon as you turn the key to run the radio will communicate with the vehicles computer and lock, but you can just pull the fuse again if you want to retest it. $75 is pretty steep for all that is involved, I would make a couple of calls and see if you can find a better deal. It only takes a few minutes, I only paid about half of that.
TexazReece
Thanks , I will try pulling the fuse and see that could save me $$$. Thanks again :biggrin:
Firebaugh86
