First of all, cabin air filters.
I have the part number for the filters from the OS and I have an '03 to put them in, but before I buy, I want to know if they will solve my problem:
Whenever I run the a/c dust/debris is blown out of the vents. I keep my phone in the "big gulp" cup holder and after just 5 minutes of driving, the screen will be covered in said dust with a fan setting of 2 or higher.
This never happened in the winter running the heat, just the a/c. Will the filters cut down or eliminate this dust?
Second, what is the purpose of the recirculate button? Note, I have the manual HVAC controller with the temperature sliders.
I was under the impression it caused the HVAC to pull cabin air as opposed to exterior air and that was it.
After my a/c got fixed, I noticed the recirculate button turns on the a/c and blows cold air without the snowflake coming on.
Whether the snowflake is on or off, recirculate turns on the a/c (as long as the sliders are in the blue).
Is this the intended function? Why can't I just cycle the cabin air?
In the winter the recirculate button is able to come on, what does it do when the heat is on? Cycle and heat the cabin air?
Also, why can't recirculate be activated on the digital HVAC controllers with the heat on? I've tried this in numerous GM vehicles and recirculate just flashes then goes off on the fancy digital controllers.
Is this an easter egg of the manual controller or does it not do anything?
Thanks for any insight!
