turbo injector help
00brado
i have a rear mount turbo i want to install on my silverado but i want to know what size injector to use. i looking fo something stock that will work. i have a 2000 silverado with a 6.0 with stock intake. i will be running max of 5-10 lbs of boost. i will have it tuned. i just really want to know what stock car i could get the bigger injectors from.
i think 42lb injectors are the largest stock injectors on gms. but those are car injectors and require height adapters for a truck fuel rail, not cheap unless you get a deal
i'd say your best bet is to look for someone selling the 47lb injectors that come with the maggie superchargers, you see them for sale by people who needed to step it up.
Thanks jimmy. Now I read that some were that a guy used some 38 out a Ford so does that mean that the ZO6 37 will work. I don't want to Ho any higher than 8lbs of boost. If I do I'm gettin a built trans.
Kobalevsky
