Congratulations...You have made a Splendid Choice for your SUV with the purchase of your Chrysler-Jeep Grand Cherokee. Towards the end of last year, my Daughter In Law drove hers (2019 Jeep Grand Cherokee) right into destruction on the interstate, not understanding that an All Aluminum Engine such as the Chrysler Pentastar 3.6L Motor will soon become -=
unusable=- if there is any mysterious Loss of Coolant either from a Failed Radiator ...or via hose connections to the Heater Core failing right at the Firewall.
Also ...with Plastic Parts for the Oil Pump Housing and Water Pump that can suddenly crack...these are Single Point Failures worth anticipating and fixing well before any issues develop by insisting on replacing these delicate plastics items with Cast Aluminum Parts.
These failures resulted in my underwriting a $12,000.00 Engine Replacement for her
($6K for the Engine and $6K for the Authorized Pro Shop Installation with extended Parts and Labor and Warranties) via
"The Fraser Engine and Transmission Company".
While a very expensive lesson in caution and care evolved from this event, my understanding of just how incredibly well designed the Chrysler 3.6L Engine has much improved. God Forbid you should have Users and Drivers of that Jeep without a keen understanding that at the
VERY INSTANT they can see or sense any Steam, Coolant Odor or Increase in either Oil Temperature or Water-Coolant Temperature... to Pull Off The Road ...
SHUT DOWN IMMEDIATELY ... and Call for a Tow... and Save that Engine from Total Failure.
By doing my MUCH Due Diligence, my choice of the Fraser Company was a Life Saver. For your benefit... Have a look at just how astonishing your Engine really is...and observe all of the Modifications and Improvements such that it comes with an Un-Limited Mileage Warranty against internal Engine Failure. As times passes... look into making any changes suggested below to ensure a very long life for your Jeep Grand Cherokee 3.6L Pentastar Motor:
Find out as much as you can well in advance of any hidden weaknesses with your Engine and Drive Train and be Very Pro-Active in making whatever changes and upgrades necessary and you will Enjoy Driving that Jeep ...
For as long as Grass is Green... and Skies Are Blue!
