I have a 03 Envoy 2wd with transmission issues. Was driving home and it just went into neutral. No sounds or smells of any kind. I took the trans pan off and I have power to all 4 shift solenoid with the key on. No power to the pressure control solenoid though. Is it supposed to? Fluid was a little dark but no metal or anything in the pan. I unhooked the battery for a while and the service engine soon light doesn't come on anymore. Shift cable is fine. What could be the problem? Any help would be appreciated. I can't afford to have it towed to a mechanic. I don't have a scanner.
