NEED HELP Transmission shift linkage issues
littleblazer
9,265
Hey guys. Been having issues with the truck having the shift cable pop off the linkage lately. I replaced the bushing a long time ago so I figured it was due again. It was worn enough it wouldn't stay on so out with the old in with the new. Now the issue I'm having is it still doesn't hold the shaft great. After about 20 cycles it'll pop off again.
Now I'm curious, the arm itself looks pretty worn down where the bushing rides so I'll assume it may be time for that as well? Anyone dealt with this? I just want to not have to crawl under it every other day is all. It pops on and locks to the groove positively but I can still pull it without much force.
Any input is much appreciated.
Best,
-Paul
10,682
You could drill out the existing pin on the arm and ditch the plastic bushing, then switch to one of the metal replacement pins with e-clip. That's what I opted for like 10 years ago, cable won't move after that. (unless the cabin side bushing breaks, which mine did, years later :duh: )
littleblazer
9,265
So like the B&M setup I have on the 67.
Would you mind my asking if you could Elaborate? I just don't want to deal with this ever again lol.
10,682
Before I had a decent amount of tools and mine broke, I had to rig it to hold together until I could get some help to fix it. My friend took the arm off the tranny, drilled out the old pin, and gave me a bolt and nut with a couple of washers that held it together in the meantime. (honestly could have left it that way) I ordered the repair pin from ATF Speed, and that replaced the bolt and nut with a pin (2 actually) and e-clip. No more plastic pieces :no:
littleblazer
9,265
Sold. :goodpost:
JerryIrons
434
I used that same ATF Speed metal setup and it worked great, would highly recommend. If I remember right I used an angle grinder instead of a drill for that removal section.
I had the same mentality as you, had to crawl under the trailblazer in a parking lot during winter, and used a piece of wire to hook it up temporarily and get home. (my wife had taken it to work). Fixed it with the dorman ER fix but knew it was only a matter of time before it happened again, and I did not want to have go through that fun again if I had too :smile:
Gunner
19
Minnesota
Why does it come with two pins? Different lengths for alignment options??
10,682
No idea, it was years ago when I got them, but they appeared to be identical. If I had been thinking ahead at the time, I would have measured the e-clip, and sourced another one of the same size, and then sold the pair for cheap. :dunce: :duh:
  • Haha
Reactions: Gunner
jvest
