I just saw a video of this guy saying if you put transmission fluid into your oil and run for 300 miles in a Chevy vortex it will clean out all the sludge and stop the ticking/knocking that I have, is this true? Is it safe?
Seriously!? So this actually “might” work and quite the lifters!? No damage will be caused at all are you 1,000,000% positive? I know your a moderator which means u probably know your shit but it’s my engine and it’s something I’ve never heard of and it sounds unorthodox but I’m willing to give it a go as long as my engine won’t blow up or fry cause I can’t afford a new oneIt is an old hot rodder's trick to replace one quart of oil with tranny fluid when you change the oil to keep your engine clean. It can't hurt but it might not work if heavyly gunked up.
