- Joined
- Dec 12, 2011
- Posts
- 4,682
With 164K I went ahead and replaced the fluid and the pan, went with the recommended Dorman with the drain plug. I added some Lucas trans fix a few days back knowing I would be doing this today, which likely knocked off some varnish adding to the not-so-welcome dark fluid. Intervals have bed 30,70,120, and now 164K.
Either case, it has a slight 2-3 flare so I figure the end is near but hopefully it will chug along for awhile. I pulled the passenger side cooler line and attached a 5/16 OD hose which fit snug against the rib for the quick release. I did add a bottle of Lubegard red this time just to give it that little "extra". For those who haven't done this it's easy and here are some pics.
First thing is to get all 4 off the ground, keeping it somewhat level.
Using a small screwdriver or pick, slide the black collar back to reveal the snap ring.
The snap ring can be pushed out easily with a pick, just be sure to hold on to the other side to prevent flight. Lift one of the ends of the snap ring, not the loop part.
Slide the hose over the flare of the tube and it will stay, no need for a clamp.
I pumped out the fluid until it bubbled and it dumped about 6 quarts or so, let it sit a few minutes and started it again dumping about another quart or so. This way the pan will be near empty making the removal easier.
Was going to use the brass fittings to keep it weighted down but clamping it high was the better alternative given the fact I wasn't using a clear tube.
First dump
At this point I went ahead and removed the pan and filter. I reused the filter seal since the fit was still pretty snug.
Remainder of fluid in pan, so far....no mess.
I used the box it came in to catch the drips, sides work great to keep the breeze from taking fluid all over the driveway.
I laid the gasket out and pushed in 4 bolts to hold it in place. The right rear corner bolt leave out since the bracket holds the pan close to the valvebody.
I refilled the dipstick tube with 1 gallon of ATF (Maxlife) then restarted until the flow stopped. Did this again and on the 3rd drain I started seeing cleaner fluid. Grand total in bucket was about 14 quarts....four 1-gal jugs is what you will need having about 2 qts left over.
I could have easily pushed another 3-4 slightly dirty quarts out but this will work. Next time I will get the quick-disconnect tube and use the other side so I can drain the cooler but either way will work fine.
Not really the shade of pink I was looking for today... but I can say on the dipstick it appears much lighter, even on a white rag. Nonetheless that's some dark fluid and I will be searching for some rebuild kits sooner than later.
First dump
