HI, So to make long story short, I replaced the trans cooler lines with braided hose. When I installed the fittings on the radiator I noticed that the inside threaded part that the fitting goes into had pushed into the radiator. Both of them did this.
It's hard to explain but the original fittings had a large outer ring like a flat washer attached, so that would press up against the rad and thus pull out the inner threaded fitting and when tightened and nothing leaked. It's as if the trans cooler inside the rad is loose inside of the radiator. In order to achieve the same seal as the original fittings, I had to use a big washer on the new fitting, which accomplished the same thing as the original one.
I hope I explained that well enough.
My questions are has anyone seen this before and if it's not leaking, do you think it will be ok? Thank You for your help!
