Hi guys,
I have an issue with my Trailblazer and would need some advice. The 4wd service light is on and the car seems to be stuck in 4LO. I have disconnected the ATCM fuse (number 8) and disconnected the battery without any luck. I also tried to rotate the selector switch back and forth for about 30 times.
I did a diagnose with my MD802 and it showed no fault codes except for in the specific code section that shows C0327 which indicate that there's something wrong with the transfer case encoder motor.
I'm trying to narrow this down, and see what you think;
4wd service light is on all the time
When turning on the ignition the four lamps above the selector switch blink one time, when start the engine they blink one time for about 1 or 2 seconds then went out. No lamp shows when turning the switch in neutral except for one time when both 2HI AND 4LO where constantly on at the same time. No clonking sound from under the car either.
Is there any way to see if the transfer case encoder motor is faulty with the diagnose check, if so how? What readings should I look for?
How would you continue to pinpoint the problem??
I guess its either the encoder motor or the TCCM or the wiring, but how to check it without replacing components??
Can you feed the Encoder motor solenoid with 12V and see if it works that way?
Thanks
Matt
Thanks
Matt
