- Jan 22, 2014
- 359
So I originally started this out on another forum, but apprantly this one is the best to pose my questions and situation to.
Anyways, we have a 2003 Envoy XL with the 3.42 gear ratio, 4.2l l6, 4x4. According to the VIN decode, it says Gross Vehicle Weight/Brake System is 6001-7000/Hydraulic.
The door tag says GVWR = 6400 lb, GAWR FRT = 3200 lb, GAWR RR = 3400 lb and then a few lines down Model T15806 Payload = 1353 lb.
I have also read somewhere that towing cap for this vehicle with the 3.42 gears in 5100 lbs?
Now this is my wifes truck. She bought it new in 2003, said it had the towing package on it, as is evident by the factory hitch.
Why I am asking all this? Well we are looking to purchase a travel trailer, which is stated at 4380 lbs dry weight. Add in a 30 gallons of fresh water, now were at say 4620 lbs. Plus some food and clothing...and other stuff. Website also states hitch weight at 460.
Anyways, I am think we are at close to max, if not a little more. I know we aren't going to break any land speed records, or get very good gas mileage, but that doesn't concern me. I plan on picking up a brake controller and a weight distributing hitch. I'm fairly certain the truck has a trans cooler, but would an additional one be necessary? I also read a thread about adding or replacing some anti-sway bars, which for around $100 didn't seem like a bad idea.
At any rate, is this kind of tow doable, assuming we aren't climbing mountains and what not? Basically we want to be able to pull this thing now in state (michigan), but maybe a few years from now upgrade the truck so we could take a trip out west.
Thoughts? All the numbers are somewhat confusing.
