Thrust washer
2002tb4x4lt
2
CA
So had a problem, I've been hearing this noise from the rear end so I opened up my differential and just sitting there was one of the thrust washers off the spider gear put it back on a couple days later here another noise opening back up the thrust washer is sitting there again does anyone know how you even came off with that shaft going through the middle of it
7,709
Assuming you do not have an Eaton M-Locker flavor of this "Pumpkin":
Firebaugh86
