- Mar 24, 2014
- 76
Hi All,
Hopefully this is an easy one. Today I cleaned the Throttle Body on my Envoy. I disconnected the positive terminal from the battery during the entire process. Just took it for a test drive and it ran great for a few minutes, then the Reduced Engine Power lamp came on, with a Check Engine. I don't have a code reader, my guess is I did not allow the PCM to learn the new setting since cleaning.
I should mention that if when I shut the truck off and restart, it runs great for a minute or two, then the Reduced Power comes on again.
Do I disconnect the battery again to reset, or am I best to pull the two PCM fuses?
Thanks in advance,
Adam
Thanks in advance,
Adam
