I'm testing a suspected bad abs module , the abs is kicking on at low speeds for no reason and it is killing engine power at low speeds as well .
Data logged the ABS module yesterday and found some interesting information.
so in park with engine running all 4 wheel sensors read 2mph
after driving around finally got the abs turning on on data log , front 2 wheels sensors drop to 2 mph rears still read 3 and its dumping left front wheel valve .
there was a stored but not active code for steering angle sensor as well .
is this enough info to consider the module bad ? are there any other tests to perform ?
i can send a copy of the data log if anyone would like to check it out as well.
