- Apr 9, 2012
- 64
I promise my posts will be easier to read than my title.....but I have to get your attention first
The story:
i was driving along as usual, in TB bliss, just going about my day. Right before parking I noticed that the windows didn't work from the master switch, but since they were up and I was parking it I didn't really think that much of it. When I tried to restart everything was dead, and no crank. Can't check for codes with scan tool because OBD2 port does not work.
Key in position 1 (acc)
Working-seats, headlights
Not working- Cluster warning lights, P/W, radio, dome (except when turned on by headlight switch), remote locking, 4WD switch lights.
Key in position 2 (ON)
Working- Seats, Headlights, Cluster warning lights, Gear position indicator (but no line under the letters)heater blower, rr defroster, turns/hazards, mirrors,
Not working- Radio, 4WD switch, remote locking, P/W, dome (except when turned on from Headlight switch)
Key in Position 3 (START)- Nothing happens except the dash gets dim.
There is 12.6 volts at the 1year2month old battery.
The starter spins and cranks the motor by jumping the pin locations where the relay goes. REPLACED RELAY just for insurance. REPLACED IGNITION SWITCH for insurance.
I've checked every single fuse under the hood and back seat, and verified continuity of each fuse with a fuse tester. I also pulled every circuit breaker just for good measure.
I pulled and left out for an hour the PCM fuses to attempt a reset. I've inspected the area wiring in the tailgate and pulled the main window switch, nothing out of the ordinary.
I finally had to give in and have it towed to my trusted mechanic, but I don't know if he has the right tool to interface with the PCM and BCM to analyze them. Neither he nor the dealer could look at it before Monday, so I brought it to him because he'll be cool with me under the hood in his lot over the weekend in case I gain a wee bit of miracle insight and can fix it. Plus, if I have to replace a module he will let me bring my own. Either way I have to pay for a flash at Chevy.
Any help troubleshooting this is more than appreciated. I have searched and searched, and looked for bad grounds, frayed wires, shorted this and burnt that. Most of the threads I've found here and around the interwebs don't describe quite this level of total deadness, so it must be something simple I just haven't found it yet.
The story:
