Hey y'all. Just noticed that my T-Case and headlight indicator lights stopped working. There are no codes so I'm assuming a fuse popped on me. Anyone know which fuse it could be?
Ryan
Ryan
Don't assume, troubleshoot!
If the devices still function properly when their respective switches are activated, then your light bulbs are blown and need to be replaced (with LEDs of course )
None of the small light bulbs are fused, the interior lights that come on with the parking lights are on a single fuse, that's it though. Just imagine how massive our fuse blocks would be if each light had it's own fuse.
If your indicator lights were working, then stopped for a while, then started working again, and now stopped working again, THAT would be weird. This just sounds like they reached the end of their lifespan.
Guess this means I'll need to pick up a bezel and new instrument cluster need else aswell, huh? Gotta get everything to match, yo.Mr. No mod. Time to mod lol.
So not sure if this is related or not but I noticed my auto headlights no longer work. I tried pressing the button 4 times, multiple times and no luck. Should I move onto replacing the switch?
Are you talking about the dome over ride button? That's for DRL cancelling. If you turn the switch to parking light or low beams, do your lights come on? If so, the switch is not your problem. You'd need to start trouble shooting at the photoelectric sensor in the center of the dash by the windshield.
Flipping the switch to the left from the auto position, should cancel, and re-activate auto lights.
But what about the indicator lights in the switch? IIRC, they are controlled by the BCM. A check of the schematics would confirm this. Are the fogs working(if you have that option)?
The light should still come on if you turn on the headlights manually.
I'll check those after work and report back.Check fuse 7 and 32 under the rear seat
