Sway Bar link washer
davidevans89
20
I ordered AC Delco sway bar links and they came with only one washer for both driver side and passenger side where would this single washer go?
Is that an ACDelco? If it is, that would be their "Advantage" line. Anyway, the washer should be behind the bar. I other words, before putting the stud through the bar, you would put the washer on first.
davidevans89
20
on the sway bar or the lower control arm?
Both. they prevent the small shoulder from digging into the bar and A-arm.
Good idea. I had both holes egged out because of that. And use red Loctite on the nut.
Mounce
13,667
Tuscaloosa, AL
I'm not sure that I've ever even seen the washers mentioned and any replacements that I've looked at don't have one pictured so idk.
Look like cheap nylon lock washers I use on snowmobiles.
davidevans89
20
another question so I am also replacing my struts all around, (all struts, ball joints, sway bar links, and tie rods) the passenger one as i removed it, the yoke obviously moves side to side but there is a little play forward and back around the bushing, if I do not replace this bushing will it cause uneven wear on my tires?
I just had a look at them at RockAuto and these are the cheap advantage line, which oddly enough look exactly like Raybestos' service grade. And get this, for the Professional line, they don't have those aluminum bodied, zerkless and Allen wrench in the stud anymore. They have these nice ones with hex and blue boots, which exactly the same as Raybestos' Profvessional grade.
Do you all think that....no! ACDelco is made by Raybestos?
This is a pic of the ACDelco Professional.
Sorry, while I was writing this, you posted another question.
I guess you're talking about the axle? or are you talking about something else?
I'm pretty sure it went behind the sway bar.
gmac310
If memory serves, I think one part is thinner than the other. I can't remember if it's the sway bar or the control arm but the washer would go on the thinner part as a spacer before you put the end link on.
Not necessarily. I remember the back of the stud just pulling into the bar, which I think has softer metal. Anyway two is better.
davidevans89
20
So I plan on taking one of the old washers and the new one and putting them both on, so thread the washer on the stud put it through the hole (sway bar/lower control) then thread the nut one?
Sway bar link/washer/vehicle part/then nut
No the yoke at the base of the strut, pictured below and outlined in red.
It wobbles forward and back (bumper to bumper side) like the rubber spacer may be worn, just wondering if the spacer is worn what would it cause? Premature tire wear?
All it does is hold up the A-arm unless the movement is so great that it's like a bad strut. I haven't heard of anybody replacing that bushing. It's seems to be available at the dealer ($53 at GMPartsDirect) but I have no clue how it's done. If it really is bad, I'd replace the entire arm as it would come with a new balljoint and new bushings all around.
davidevans89
20
Any idea on how to tell if you need to replace a control arm?
Also if I don't replace the bushings at the base of the yoke and control and would that cause uneven tire wear?
Worn control arm bushings could do that by altering the alignment, mostly the camber and caster. For the yoke, might make noise more than anything.
paul2005tb
299
Massachusetts
I took my sway bar links off today. I notice an absolutely superior ride quality. Much softer ride, no comparision. Sway bars are for race cars.
I think I will not be putting them back on. I drive very slow and never take corners or exit ramps at speed.
davidevans89
20
So getting an alignment and I won't have any worry?
This week I did all new ball joints, struts, sway bar links, driver tie rod, and rebuilt my front axle disconnect, getting new tires this week and an alignment. Not a lot of funds at this moment for more parts
They will check prior to the alignment if anything is worn/loose preventing proper alignment. Alignment should be done BEFORE getting the new tires just in case.
paul2005tb
299
Massachusetts
davidevans89 said:
Yea I don't get why it came with only one washer, maybe I could use one of the old ones
I think the design idea was that the sway bar link does not turn with respect to the lower control arm, (the lower control arm simply pushes it up) hence no washer there. The turning movement/articulation is between the sway bar and the link and that end has the washer. That is my best guess having been under there removing the links a few times in the past 4 months.
BrianF
1,193
West central Sask.
Old thread but I ran into this issue. I would have preferred washers top and bottom but ended up putting them on the control arm/frame mount. This was on the premise that I will source some washers and the easier of the nuts to remove (on the swaybar) will come off for the new washers.
How much torque did you use? First couple of years, GM had a lower torque value and had problems with them getting loose and egging the holes. I had the same problem with my first TB. I wound up just using the breaker bar with red Loctite.
BrianF
1,193
West central Sask.
I did not use Loctite but used as much torque as I could apply. I used a snipe or a large wrench on the end of the ratchet where I could. I will monitor and after a few hundred km will tear down and inspect. What ever coating they used, you needed some decent torque just to get the nut seated.
Camdo
74
  • The GM manual states for replacement of lower control arm bracket:
  • “Important: There is a washer between the stabilizer shaft link and the lower control arm made of hardened steel and has a felt inner liner. Only replace this washer with an identical washer, standard washers should not be used.
  • Interesting, the GM manual does not mention this washer in the section on stabilizer shaft link replacement.
  • The GM parts diagram shows no washer in the parts list.
BrianF
1,193
West central Sask.
So it appears I got it right... time will tell. I mean the instructions that came were mighty detailed and helpful....
Thanks for the info!
JerryIrons
434
Just to add to this thread, in case anybody wonders about this. It's very confusing, because in my 06 manual, for installation of the end links, there is no mention of "that washer".
However, in the control arm removal procedure, you have this: (look at step 6)
and finally, as was mentioned before, on the install:
Of course, my replacement end link washer has no felt, I don't think they ever have. And I also use red loctite, and my torque wrench for this job is a 3 lb hammer hitting them as tight as I can (within reason) And letting the vehicle sit for 24 hrs if possible to let the red loctite set up.
7,734
From 1AAUTO.COM … In their Trailblazer-Envoy Front Anti-Sway Bar Links R&R Video around 3:06 ...They show a Side X Side comparison between their AM brand and the removed OEM one. Note the prior portion of the Video where a Saw-Z-all is being used to cut through one of the mounting bolts for orientation of the Old Washer Location in the Still Image attached below:
joeredspecial
68
Bumping this old thread with the same question, but for the rear on my '08. I've changed these out on my '02 more times than I can count but I've never received a single washer.
What's the consensus? Top or bottom and in what order?
06_4.2_4x4_ls
