My truck came with a G80 3.73 equipped 8.0 rearend. While it has done alright with my big tires and multitude of modifications, I have always wanted more strength and reliability than the G80 8.0 offered. I have the sensors out on the end of the axle tubes requiring an 06 or newer rear and never found a 8.6 for a decent price. I got it in my head to swap to a lower gear set as well with the 35s going on as a permanent fixture soon. The front diff was the real sticky part in the gear change, but I found a decent price on a unit from an SS offering 4.10 gearing and the guy happened to have a 4.10 SS rearend as well. Bought them both as a good package price. The SS rear has 4.10s and a G86 limited slip rear differential. While the gears were to my liking, the LS was not going to meet my needs. I found a new in box LockRight lunchbox locker and snapped it up, but to facilitate its use I needed an open carrier. I sourced a used open carrier from WFO Concepts and got them to press on some new Timken bearing before shipping it and a super shim kit to me.
So now I had all the parts to step up from the 8.0 3.73 G80 rear to a locked 9.5 4.10 rear. The SS rear is a semi-float 14 bolt often found in 3/4 ton truck and in all SS TB's. It boasts a 9.5 inch ring gear, 33 spline shafts of good diameter. The general consensus is that this is about the equivalent of a Dana 60. Much stronger than my setup was.
I thought of attempting the carrier swap myself, but decided that enlisting some help from experienced friends would be much better. Even though I really was only concerned with backlash and pattern, I am glad I did not go it alone, but would not hesitate to do it again. Had the rear came with an open locker, this would have been a couple hour drop in job, but since I had to swap carriers...no quite so easy.
How about pics....
The Donor...08 SS
Junk stripped off
Ready to get to swapping
The help and axle on the sawhorses- Started about 8 Friday night
The locker
The motivation
Sticker in locker box
Cover off- Actually really clean with no metal clunks
Dirty inside
Cleaned up inside
The LS carrier had no gussets for strength
The open carier did...
Work
Help
How about pics....
The Donor...08 SS
Junk stripped off
The locker
The motivation
Dirty inside
Cleaned up inside
Work
Help
