If you are going to have all of the additional gear necessary for performing Pro Grade Auto Engine Diagnostics using your own flavor of an Oscilloscope (PICO-Scope, Hantek, Autel U-Scope, etc.) Your "O" Scope Kit" cannot be complete without having a few types of Standard Wired Coil Induction ...AND ... Coil On Plug Probes.
Considering the High Price of a Snap-On Paddle Probe being in the range of $1,000.00 ...THIS Deal from Amazon on The Hantek Model# HT25COP Sensor Paddle Probe with LED for Only $106.00 is an Absolute STEAL...!!!
https://www.amazon.com/dp/B08153JDVS/?tag=gmtnation-20
This Device is indispensable for the proper understanding of and the FAST Engine Misfire Diagnostics for determining with precision what is happening with the COP Ignition System Primary and Secondary Wave Form Analysis, the Condition of the Spark Plugs, the behavior of Inner Cylinder Four Stroke Ignition, Compression and Power Issues and so much more... a Bargain like THIS one should NOT be 'Shined On'.
Even if you are just getting your feet wet with using an Oscilloscope or have been reluctant with reasoning why such a diagnostics system can make your life easier... Grab This Deal NOW...and you can look over the GMT Nation Thread on this subject HERE:
https://gmtnation.com/forums/thread...hantek-1008c-oscilloscopes.20423/#post-624647
...and you can study Paul "Scanner" Danner's linked Video on Engine Misfire Diagnostics Wave Form Analysis using an AES Wave "U-Scope" Oscilloscope to see all of the benefits of its use for COP Trouble Diagnostics on the GM Atlas Vortec COPs a bit later on:
...and HERE... Paul actually demonstrates the Use of an AES Wave Paddle Probe with his AES Wave Hand Held Oscilloscope simulating an Open Plug Wire situation:
