- Apr 9, 2012
- 932
Hello everyone!
I've been having an issue with my Avalanche for the past year or so. When I purchased it originally with 79k in 2013, I would average roughly 14-15 around town/city driving and 18-19 on the highway. As of late, within the last 2-3 years the fuel economy has tanked so I average around 10 to 11 MPG...with summer blend and roughly the same maybe 1-2 MPG less with winter blend. Highway driving is roughly the same, probably about 17.5-18 give or take. Not sure if this matters, but I did keep it in storage during the last two winters, and brought it back out for the remainder of the year to drive around when doing work on the Envoy.
Yeah its a brick so I should not expect stellar MPG, but the drop seems to be big enough to look into. I'm not too lead footed either with it so I'm trying to see where a good place to start would be.
Thanks!
What I've done so far;
Tune up with AC Delco Iridiums at 89k
Swapped the wires 2 months ago when I started to have a rough idle which immediately cleared up
Cleaned the MAF Sensor. I was going to clean the throttle body but it looked fairly clean without much build up.
Replaced the Coolant Temp Sensor when I did the water pump/belts.
Ran a tank with two bottles of the Techron concentrate plus. If BG44k is worth buying, I'll try throwing that into the tank.
No engine lights/codes
Specs:
05 Avalanche Z71 (1500) currently at 101,779k
5.3 Flex
3.42 gearing
4x4
Thanks!
Specs:
5.3 Flex
3.42 gearing
4x4
