jbones
- Joined
- Dec 5, 2011
- Posts
- 658
Story is this, I have an "08" and a few weeks back I found I was in 4LO
; early morning and I hit the selector instead of the rear wiper. Figured this out after a got to work and was turning into parking spot at a slow speed, drove some 20 miles on wet and dry pavement.
I may be paranoid fearing I screwed something up since it can’t be good for the system, but it feels like when driving the fronts feel a tad grabby and pull, and there’ a different rougher vibe felt through the gas pedal.
Changed case fluid last weekend for the 50,000 mile change, it looked great, see no leaks anywhere underneath. I’ve cycled 2wd -4 lo properly on a few occasions to check and no bad noise, jolts, grinding clunking, and yellow selector light goes where I select.
I’m I paranoid, or is something wrong? What do you think?
; early morning and I hit the selector instead of the rear wiper. Figured this out after a got to work and was turning into parking spot at a slow speed, drove some 20 miles on wet and dry pavement. I may be paranoid fearing I screwed something up since it can’t be good for the system, but it feels like when driving the fronts feel a tad grabby and pull, and there’ a different rougher vibe felt through the gas pedal.
