Block Heater Experiment out of MichEnvoyGuys stomach flu day off of work boredom:
FAIL
Ill tell you why.
While the ECT may be in the general area of the block heater, it obviously isnt directly submerged into the same jacket of coolant as the block heater..Read on:
At 3pm, I got hungry and it was time to check the ECT via scan tool anyway. I hooked up the scan tool, turned the key to on, connected and the ECT was at 50*f. Whatever, its 35*f out. I was thinking either my block heater was bad or ... who knows. My ECT is brand new.
Started the truck with the scantool still hooked up. Within 5 seconds of starting, the coolant temperature via ECT reading jumped from 50*f to 112*F. I had ever so slightly warm heat out of the vents. By the time I reached the end of my street (~1/2 mile), I was at 161*f ECT reading.
After ~3 hours, it made a remarkable difference but
not one you'd immediately see at the ECT reading before the truck was started. After I started the truck, it really circulated the heated coolant, apparently right over to the ECT area too.
I havent used the block heater in 2 years or so, I didnt remember its past operation aside from I hated the orange plug sticking out my front grille/bumper area. I noticed that during this trip, with the block heater pre-heating the engine for 3 hours, my avg economy on my DIC did not decrease. However, any other day with these temps, during warm up it would decrease anywhere from .2-.5mpg average and slowly work its way back up to my running avg throughout my daily driving.
Sorry I couldnt produce the results the OP was looking for.. at least not directly. However, in my little test, Im going to conclude that ~3 hours of the OEM block heater, will get your engine to +60*f above the ambient temperature. Im sure if you left it plugged in longer, you'd attain higher numbers
