good evening everyone.
Please tell me about the angle of Turns Lock to Lock in Rack and Pinion.
The parts of the factory are equal to both left and right.
After rotating 360 degrees, rotate 270 degrees.
Round 1 and 3/4 on both left and right.
The new Rack and Pinion is not equal.
After rotating 360 degrees on one side, it rotates 270 degrees.
However, the other side is rotated 360 degrees and then locks around 180.
One side turns 1 and 3/4, and the other side has only 1 and 1/2 rotations.
This is before attaching to the vehicle.
I rotated it to confirm the centering.
I thought about being a defective product.
But maybe not?
For example, if Rack and Pinion is attached to a vehicle, fluid is filled and air is removed, is there any possibility that it will return to normal?
It looks like "SHIP OF THESEUS".
thank you.
But maybe not?
thank you.
