Just recently my daughters car seems to be floating, the steering wheel has a lot of play but only when driving 25mph+
Driving in a parking lot the steering is responsive, go down a road around a corner and u have to turn the wheel a bit more till the front end turns. I have not noticed if this goes for both directions or not. 75mph on highway seems worse.
right rear sway bar end was wasted and I figured that was it even though that makes no sense with play in the steering wheel. I replaced that and no change. left side is fine fronts are fine.
I know the racknpinion is leaking fluid but its not low. steering turns fine.
So is this a sign the racknpinion is worn out?
thanks
thanks
