speedometers needle ticking like a clock?
kon
21
Long story short i re did my stepper motors an fixed my speedo an other things not working.
Evrything has been fine for 2 months or more an yesterday the speedo needle strted tickin like
a second hand on a clock instead of gliding smoothly. Then the needle droppd.below 0 down to
6 oclock position when i shut the engine off. Anyone has a idea on what it may be? New cluster needed?
DDonnie
2,631
before replacing the cluster i would try and swap around the steppers. I know you just replaced them, but you may have gotten a bad batch. Maybe swap it with the oil pressure one since that one is a joke anyway.
kon
21
Even though its worked for 2 months already?
jonbo2002
213
probably, bad replacement parts work all the time for a short period and then go bad. I agree with Donnie, try swapping it out.
AtlWrk
674
It could just be a cold solder joint or cracked trace that finally gave way. That would explain the jerky action if one coil wasn't connected well. Before swapping I would inspect the joints very closely and even hit em with a soldering iron again if you see something obvious. Or it really could just be a bad motor :frown:
DDonnie
2,631
:iagree:
kon
21
Jeanyus!
Thanks ill def check that out soon. Im bouta do my first oil change so im excited lol
prolly ti.rrow or day after ill try to re solder it n.ill leave a update
HighTechHD
