Hi, After getting the transmission and everything put in and back together, I now have a P0502, no speedo and upshifting happens but very late and well it's just not right. I have an awful feeling I may have damaged one of the wires and in a place that's not easily accessible. I accidentally pulled on one of them. I repaired it, (soldered and heat shrink), but I'm really afraid I might have pulled on it so that it broke way up further in the harness as well in which case, I am screwed I think.
My other problem is that I think I ran the wires to the transfer case wrong. There was one wire that was clamped to the bracket that holds the exhaust in place. But the way I have them run now, on top of the TC, there's no wire that would possibly reach that clamp on the exhaust bracket so I don't know what I did wrong. I'm just disgusted with myself at this point. I can't get a single person to come and lend me a hand. I'm running out of steam on this project to be honest. It was supposed to be a trans swap and turned into a trans rebuild (did it myself), power steering pump replacement, PS cooler, radiator, wheel speed sensor, ball joints, brake job, rust removal project along the way. Plus it's cold as heck lately and it makes working on it with no heater in the garage a pain when it's 15 degrees out.
Sorry for the rant.
So I guess my first question is, does anyone happen to know if the 3 speed sensors on the transfer case all share the same part number?
Thanks in advance.
Sorry for the rant.
Thanks in advance.
