JerryIrons
Well-Known Member
For the first time in my life, I am replacing speakers, the 2 rears are shot, and the front passenger speaker is bad. I went to best buy and picked up a pair of pioneer TS-G650 speakers, nothing fancy but better than ones that don't work. As far as I can tell, I do not have bose speakers, they would actually say bose on them right? Of course, now that I have dug into this more, the speaker world in general is much more complicated than I expected, I am bringing myself up to speed on this stuff, instead of just making sure the size is right... The speakers I bought are 6 1/2 two way coaxial speakers, 4 ohm. I bought the adapters as well to make them plug into existing wiring harness.
Rear speakers:
original has 15242746 on it, and 8 ohm impedance.
Question: Can I use the speakers I bought (4 ohm) to replace these?
(I have already installed one and seems to work with brief testing)
I am thinking I need to put 8 ohm speakers there because the 4 ohm uses more power? How much does this really matter?
Front speakers:
original has 10366739 on them, with 4 ohm. There is also a tweeter in this assembly, separate from the speaker, and both share the same input and output wires. The tweeter actually works if I crank up the volume.
Question: Do I need to buy a different speaker for this? Because there is a tweeter on the side, I need to get a woofer? A coaxial speaker actually has a woofer and a tweeter built onto it from what I can tell.
Rear speakers:
Front speakers:
