You can peak inside the grilles in the dash, if there are tweeters, you have Bose. If not, they're running off the head unit.
Depending on your weather, and if you have a garage to work in, you can try swapping one of the rear speakers with the front if it's non Bose. That will tell you for sure if it's a speaker issue, or wiring in between.
