SOLVED! Something broke in shift linkage
Was turning around in driveway, went back and forth a few times, placed in Reverse and backed up, went to place in drive and the shifter went easily into the 1st gear position but stayed in reverse.
I placed the shifter in Park and the trans stayed in Reverse. Also, when I tried to take it out of Park, the shift interlock wouldn't release with the brake pedal depressed.
So shifter is stuck in Park, and trans in Reverse. Is this the common plastic bushing?
Thanks.
Probably.
10,665
At least you were fortunate enough to have this happen when you were at home, and not out somewhere.
No doubt. I don't want to jinx anything, but the only 2 times where the voy was disabled, was in the driveway. Starter about 5 yrs ago, and the linkage.
I picked this up today, for the life of me I cannot get the bushing on the linkage. Found the part# on other forums, maybe 2002 was the odd year, or I'm doing it wrong.
10,665
You got the remnants of the old bushing drilled out completely? That looks like the kit that comes with the transmission side bushing as well as the gear shift lever one (I had to replace that one too). If you've got the time, may be worth checking that one too.
aaserv
408
N of Baton Rouge, La.
Put a couple of those in and they are a Bxxxx... If I remember right they have to go in in a specific direction. I fought it like crazy , swore they wouldnt fit and just before pulling out the drill to enlarge the holes I got em in.. The last time I replaced them I brought to a buddies shop cus I figured it would be easier on a lift. We fought for awhile and then he came up with the idea to put 1 bushing in and then a bolt with a few washers to hold it all together and that held until I parked it a few years ago. If I get time tomorrow I may see if I can lift it a lil and get a pic of it.
To be honest the 1st time it broke i put it together with about 5 zip ties and my daughter drove it like that probably 3 years or more. Never did break , I just saw the bushing kit in a parts store and replaced it.. Probably would just stick with the zip ties if I had it to do over again...
Mounce
13,667
Tuscaloosa, AL
Had to use a pocket screwdriver to get one in the TB. It's such a tight fit that it won't just snap in, the lip has to be forced past the lip on the cable and the plastic isn't stiff enough to hold up when just pushing the bushing in.
christo829
497
Fairfax, Virginia
Seconding what Mounce said. When mine broke, I had to push in the rim of the new bushing (with the aforementioned pocket screwdriver) to get it to go through the shift cable hole. Once I popped it through I had to then press it back out so it could snap over the pin on the shift arm. Loads of fun to do in the office parking garage. Luckily I was able to get it rolled back in to a parking space when it let go right after I backed out of my space and put it in drive...
I now keep an extra in the tool box...
Good Luck!
Chris
The kit I have now (14057) does not come with this bushing here on the right, from kit 14055:
I believe that's the correct bushing on the right. The plastic end of the shift cable has a recess on both sides, and the smaller remnant I removed was on the end opposite the trans linkage. I'm going to try that one tomorrow.
I hear ya, I ended up using the larger orange bushing to take up slack and wired it together with some 28 ga wire to get to work and back. I fought the clear ones for 30 min to no avail, but I believe those clear ones in kit 14057 aren't the correct bushings.
Mounce
13,667
Tuscaloosa, AL
Ya'kno. I was gonna check and make sure you had the right part number but glanced at your picture and said 'yeah that looks about right' and passed it off.
14055 is the correct kit though.
And I also keep a spare.
Reactions: gmcman and mrrsm
7,639
Reactions: gmcman
I looked up both numbers on Amazon and both says will fit. In the reviews, both mention to fit on GMT360's so ???
@gmcman , will wait to hear your results before I order a set since it is likely just a matter of time before one of mine fail.
Was able to re-attach the linkage today. This is the kit I used: Dorman 14055
Includes two pieces, this is the piece that is used at the end of the linkage at the trans:
I used a light film of lithium grease on the outside to ease installation, and it pressed in easy to this point.
With light pressure using a flat blade screwdriver it went in quite easily.
All is good. I wish it had a little more grip on the metal post but it didn't feel like it was going to pop off either.
And also confirm that part number.
Reactions: Matt and gmcman
Camdo
71
Fell into the same trap. I purchased 14057, fought for and hour trying to install the white bushing only to fail and wound up using the orange 2 piece bushing which I definitely do not like because it puts the the cable center line so far away from lever ball and nearly hits the transmission case. Wish I read this post first. Thanks gmcman I'm going back to the store for 14055.
10,665
I just saw this on another forum:
I think I'll go ahead and put it on my '04 TB before the plastic one from the factory breaks.
That's the one I bought years ago when mine went... A friend of mine who had his bushing fail around the same time as mine, who went with a Dorman replacement, had his fail on him again last week. We're putting the metal pin in it this weekend.
Camdo
71
My shifter lever had a rusted ball so I replaced it with Dorman 74124. It is not necessary to remove the transfer case drive shaft. The shaft center line is above the drive shaft. It was an easy job with a 3 inch socket extension. Torque nut to 18 Ft-Lb. Dorman says it fits 4 speed transmissions. Mine has speeds 1,2,3,Drive, so I guess that is 4 speed. It looked like a perfect match against the old lever. I also used the shifter cable bushing Dorman 14055. It installed and worked perfectly. Thanks gmcman. I was tempted to smear some Never-Seize on the ball joint but decided it would attract dirt and grit, so I left it dry.
2005 GMC Envoy SLT 4.2L
Reactions: Redbeard and mrrsm
10,665
Tried to do this today on my friends XUV, but I had issues drilling out the old pin. Considered taking a cutoff wheel to it, but he also had the Dorman kit handy, so we just lubed it up and pressed that in. Too hot and humid to keep messing with it, even in the garage with the high speed fan on us.
He's gonna send back the ATF pin. :frown:
Sprung Monkey
350
Al
I have the14055 came w/ 2 bushings I thought it was the other.
So you used the bushing where ends where unequal and the fatter section is outwardish.
So this means it can’t go on backwards correct?
Sorry to sound stupid I don’t want to mess up more than I’ve already.
Thanks
Daniel644
573
This happened to me today, was leaving the grocery store, put the truck in Reverse, backed out of the parking spot, went to put it in drive and the shifter just moved with little to no resistence but remained stuck in reverse, put the shifter in park, truck was still in reverse, slapped on the parking brake and flagged some random person in the parking lot to come sit in the truck with his foot on the brake so I could slap it into park then I clicked the shifter cable back onto the stud, I felt a Click as it popped back on so the bushing isn't totally out of it, I had bought one of those Ebay bushing kits years ago when i first bought the truck but I can't find it now so ordered one of the dorman parts, gonna go ahead and replace it next weekend before I drive it again.
  • Wow
JerryIrons
434
the metal replacement one will fix it for good
Daniel644
573
OK, ordered that one, tried to cancel the dorman order from Amazon but i'll just do a return once it gets here. from the confirmation email it looks like ATFSpeed is in Florida so hopefully it can be here by the weekend so I can fix it Saturday, if not i'll wrap a zip tie or something around it to make sure it won't randomly pop off in the short term, I only drive it on weekends but I need to be able to drive it on Saturday to pickup some materials.
