Slight drop in RPM when just touching throttle
CaptainXL
Does anyone know what the cause is for this slight drop in RPM at idle just after barely pressing the throttle?
[video]https://www.youtube.com/watch?v=bwZnLth73Fs[/video]
Mounce
13,667
Tuscaloosa, AL
Didn't watch the video but, that's been asked here many times. Seems like 80% of us have the issue (including myself) and if I remember correctly, it's been ruled as normal. Of course, you could try a tune up (plugs, fuel filter, intake filter, throttle body cleaning and such) and see if that takes it away though, but it'll probably still happen.
CaptainXL
My first instinct is that this is stumble. More likely due to a vacuum leak. My scan tool data shows enrichment at idle. I guess what I am hoping for is a reply from someone to verify this. Anyone notice this stumble disappear after fixing an intake manifold leak?
May 5, 2013
434
mine does that also.
CaptainXL
So everyone's engine does this? Reason I ask is because sometimes I can catch it not doing it.
mcsteven
6,584
Mine does it too.
KNBlazer
811
mine has done it for years, and now as well with a recently rebuilt engine...
I have requested that those with a PCM tune chime in, but no one yet has come forward...
The Neens
24
Mine does it with or without custom tune installed...Throttle body is spotless...
CaptainXL
I just go done replacing the intake manifold gaskets this past weekend. Trying to track down a loss in performance.
I recently switched gas and noticed a big improvement in mileage and power. I am pretty sure half of the equation just got solved.
Still unsure if the rpm drop is still there or not.
domkan
